Hi All,
New here but I've owned a few Suzuki's over the years. I just picked up a 95 Sidekick for winter use. Automatic w/165k miles. I took it to a guy/auto repair place I've worked with in the past for an inspection and he gave me a gave a little rundown of things he recommends taking care of on it.
- get a new timing belt (says the one that's on it is old and cracking)
- replace water pump (corroded and won't charge labor since it's off with the timing belt replacement anyway)
- Tune-up
The car does leak a very small amount of oil and puffs some blue smoke on startup/take offs...I told him to run a compression check, but he didn't come back to me with any issues on that - he thinks it's probably valve seals and didn't seem concerned at all about it being a problem...also said it would be a pricey repair if I pursued it.
I'm figuring I can do the tune-up myself (I hope). Do any of you have any sites or links to recommend for any specialized info I would need to know about a 1995 Sidekick specifically in regards to distributor, rotor, etc...?
Also - it there anything else anyone would recommend I do while I'm at it - or have my mechanic look into while he's doing the timing belt/pump repair?
Any advice/wisdom would be appreciated! Thanks.
- Tune-up
