whohaahhh progress.
lots. since yours is the rare fail , so can be ANYTHING on that feed.
too many drawings , many are blk-white , all can short.
so will list them.
DRL lamps controller ( if you have it)
A/T tranny brake switch. with foot off brake THE TCC relay shorted or tranny tcc solenoid shorted, ( everytime over 45mph , boom goes the fuse)
audio alarm module. the thing that chimes when seat belts arent fastened.
Main relay (runs ECU) only of the coil is shorted to body.
fuel pump relay , only if coil is shorted . fuel pump cant blow this fuse unless this relay is belted blob of slag.
oxygen sensor heater ckt ( top fail)
Ignition coil.
Noise suppressor ( not likely, near impossible and hard to find )
Generator ( alternator regulator inside it , is shorted , unpug the rear plug on alt))
last: instrument cluster shorted. it has a blk-white feed on pin 5 that runs all the lamps and meters in I/P cluster.
