I did not buy the swap kit for the new 3k carb off Amazon but fabricated throttle linkages and made my own gaskets. Tested Vacuum and reading 18 with no signs of vacuum leak testing with carb cleaner spray test. The only thing I skipped was the thick spacer under the carb. Is this essential for the install? I used one singular hole gasket. Another problem is before new install engine started running cold at about 120 degrees despite two new thermostats and a new fan clutch. Even with cardboard in front of the radiator it still runs cool. Now there is sooty water droplets out of the tailpipe and the engine seems to be ticking louder than usual. No timing light to check ignition timing yet. Fuel filter replaced. New gaped plugs a month ago. Starts and runs pretty well but I can tell something is wrong. Timing advance actuator moves with artificial vacuum test but I have no idea if the carb vacuum is actually advancing it with the engine running. There is only maybe a full turn or two of the air mixture screw in either direction before very rough idle. Idle RPM are around 8 or 9 hundred. Runs pretty smooth after 1000 rpm but is a noisy little bugger with all the slight fast ticks that have always been there since I bought it 5 months ago. After the carb swap the ticks are definitely louder. So many problems all at once. Hard to tune a cool engine. Pretty new to carburetors. Any help would be fantastic. Thank you.
