pre 2003 XL-7 workshop manual download.
See how you go with this (the website they're on is a PITA)
1. Download the file "top.pdf" and place it into a new folder of your choice (eg. name the folder "XL7".)
2. Create a folder named "Data" within the the "XL7" folder.
3. Download the remaining file groups to the "Data" folder. Each group of files must be put into the "Data" folder within a new sub folder labeled with the same folder name as is used on the download website.
4. Once all the files are downloaded they can be accessed via the "top.pdf" file. Open that file and then select the XL-7 option. That should then take you to a menu that lists all the pdf documents applicable for the XL-7. Then click on whatever section you want.
EDIT: All files for SQ series and XL-7 pre 2003 are now available. But in English only....
The downloads are all located here. ALL the folders need to be downloaded:
mondeost24 - eSnips Profile
Click on the links for each section above. When the page opens scroll down the page to the "Files" section. Click on each file to begin the download process. Another page will open and give a preview of the document - click on the "download" option directly beneath the document preview and the file download will then begin.
