93 Tracker 1.6 8v won't start - Suzuki Forums: Suzuki Forum Site
Go Back   Suzuki Forums: Suzuki Forum Site > Regional > North America > US - West
Old 03-05-2016, 02:35 PM   #1 (permalink)
dantalbert is on a distinguished road
Default 93 Tracker 1.6 8v won't start
Hi, I bought this 93 and it was running on three . number one dead with very low compression. The others had +-150. The folks had supposedly put a timing belt in but messed up the crank seal. Before I tore into it, I checked the valves and found adjustment causing 1 to miss. I adjusted the valves, got 150 all across. Everything was covered in oil, including much of the interior, so I washed it. Pur new cap, rotor, wires, plugs. Wanted to start it before I tore into it to do the seal. It refuses to run. It will pop, lope along with the starter. It had very good spark, now, it has spark at all locations but reddish. It gets fuel, pump is working and comes to TBI. It vwont even stasrtcwith fluid. Its almost as if IRS 180 out, but it was running. Belt could have slipped, I guess, but too coincidental.if it hadn't been so saturated in oil, I wouldn't have washed it, but I was careful. Covered parts, no high pressure. Just gunk and water. Should I go ahead and do the timing belt and not worry about the starting till I button it up? Never been so confused. Control module?
dantalbert is offline   Reply With Quote Quick reply to this message
Old 03-05-2016, 02:40 PM   #2 (permalink)
Darrell.'s Avatar
I believe some aftermarket rotors can be fitted the wrong way round putting the timing out. I''ll have to check the forum out and see if I can find a relevant post, or go see if it will fit 180 degrees
2005 Grand Vitara MT 1600se.
Old 03-05-2016, 02:51 PM   #3 (permalink)
Darrell.'s Avatar
Nope, not 180 but 120.
This is the post I remember.. https://www.suzuki-forums.com/suzuki-...-position.html
Old 03-05-2016, 03:45 PM   #4 (permalink)
I owe you big time. 30 second fix. Runs like a champ. My fault for buying a Duralast, wasn't even cheap. Thank you!!!!
Old 03-05-2016, 04:03 PM   #5 (permalink)
Darrell.'s Avatar
Great news.
Thanks to the original post
