Is this the Road Race or something like that header?If you’re interested in the cost of this exhaust system it’s roughly costing me about 1100 USD to make myself including all the tools. Biggest cost was the ceramic coated headers I bought over 12 years ago. They needed some tweaking unfortunately to fit correctly, despite the changes I made, it just BARELY clears my oilpan. “Clears” meaning it’s touching. I’ll need to add some heat reflecting tape to the oilpan to keep some heat away. Only plus is that since there’s no catylitic converter there anymore, is technically cooler but still gonna be pretty hot.
I don’t think any, I’m gonna check compression again but was seeing 185 and 17X in another. Just prior was reading 0 all the way across but removed a broken piece of chain tensioner and got those readings on two of them and the car was running again.the day before was running the same and on the third time running was back to normal as if nothing was wrong. So I’m totally confused.Going to do a compression test again later. See what I’m seeing on all 4 again. Cause the symptoms make zero sense and if the car runs normally again today, I’m going to be totally lost. lolHow many bent valves?
