Does anyone know how to check fault codes on a 2002 XL-7? I have an engine light on and the engine runs rough at idle. Any help would be appreciated.
Thanks,
checking codes on you vehicle
on Sidekick 91, there is a plug near the battery, if you plug in a wire between prong 2 and 3 , then turn on the ignition key without starting you vehicle the engin light will flash you the code , do a google on "ecm code reading" you will find plenty reading in this. Good luck:D
