1996 x-90 5sp manual 4x4
Ok this is the one I bought with blown engine and in various states of disassemble with wiring issues.
Finally finished installing the replacement motor from a 94 sidekick. Changed over sensors, distributor and installed CPS and encoder.
Ok, here's where I at:
Cranks fine no start.
Did not take long to find the first issue. Fuel pump not running.
In the process of looking for the fuel pump relay...
(not near the ecu but passenger side ((LH drive))way up high toward the middle below the main relay and above a relay with a yellow connector which I assume is air bag. I'm still looking for the fuel pump ground point. It is definitely not behind either tail light and I cant find it elsewhere in the trunk.)
...so in the process of trying to find the pink and blue lead from the relay to the fuel pump I found a suzuki security device.
Anybody know if these can be defeated? If so how would I know if this one has been bypassed? I asked the seller specifically about a security device he came up blank. All I have is one unchiped key and no remote.
Is there a proceedure to make the security happy like for example a simalar vintage Toyota had a anti theft device wherw you turned on the ignition flashed the high/low beams or you either didnt start or lights and horn flashed. Or both I cant remember.
So all input wellcome on both the fuel pump ground point and the workings of the pictured security box.
I'm thinking that with the mess I have under the dash it might be easiest in the ljinnlong run to pull the dash covering off completely. Doesn't look that tough on this one. Anyone been through removing the dash on one of these and care to comment,?
3 hrs later Edit: just occurred to me that this box probably is just for break in security and unlocking doors ect. Likely has nothing to do with ignition or fuel delivery.
