1 - 1 of 1 Posts
Hi, I hv liana 07. It showing 27 temperature on digital clock in any case.
It was working fine (43) before ac service. The mechanic opened the blower and fridge for service then he washed the internal portion under the dashboard (lines which were going to ac vent)with water pressure and water was coming back in a pot he place there under the dashboard . As i started the car it was showing 27 temperature. and now it is showing the same as i start the car.
Please suggest what can be the reason. I guess he messed up with sensor though i am not sure where is it or water could damage it when he threw water under the dash to clean it.
Please suggest what should i check further?
P.S digital clock is showing the correct time. I parked the car in sunlight to see of temp will change but it was same 27.
1 - 1 of 1 Posts
