I replaced my valve cover gasket this afternoon, but to get the cover off I had to remove the distributor. I don't know anything about how the distributor works and after reading up on it I think I'm in trouble. I know the distributor was turned while removed. Now I cannot get the engine to turn over, doesn't sound like its firing correctly. I'm not certain its a distributor issue, but that's all I can think of. Any ideas?
When you remove the distributor you have to be sure it goes in the exact same position as it came out. But I see you already found this out. You have to find number 1 cylinder and top dead center. Then make sure the rotor in the dist. points to the #1 spark plug wire and then install the distributor
If you line up the timing marks to TDC and then look through the oil filler cap you will see if its on No. 1 TDC as the valves on no 4 will be open, if the rockers are loose then turn the crank another 360 degrees. Once you get the dizzy aligned then block off the vacuum advance and use a timing light to check the timing.
Gotcha. Yeah it was a rookie mistake. Anything special I need to know about finding TDC or getting the rotor pointed in the correct direction? Never done this before, seems like moving the piston would be very difficult.
Turn the engine over clockwise using a socket on the crank pulley, there is a mark for TDC on the crank sprocket though you may have to clean round it as its quite small. The timing belt cover has TDC marked on it.
