1 - 8 of 8 Posts
Factory portal only for that at this time, vehicle is too new for that to be available yet as a third party manual, what's your issue?
You will need either a controller that can simulate the vehicle speed sensor and possibly torque sensor and a heavy current supply, with a 50A fuse. Have you got the control unit on the assembly itself? The plug has 2 heavy current wires, canbus lines and speed sensor and torque sensor inputs from memory
Hi yes have controller not sure if it is right . Have tried it but no response but is putting out 2.5V blue wire 2.5V Green wire to torque sensor.
97390
97391
97392
97393
97394
97395
Got a heavy current supply on the brown and red wires on the rack controller? Is the assist rack actually ok? If it's from a wrecked one it could very well be non functioning
Yip 12V supple to red . Black to earth on controller . Ecu black earth green 12V .Yes that what I was thinking it could be faulty .
Look closely heavy current +12 to steering rack red, ground on brown. On the rack ecm, not your aftermarket controller.
Without that 50A supply the rack motor gets no power and will give no assist. Is that there?
1 - 8 of 8 Posts
