i need a front passenger window regulator , i got a second hand one from an auction site witch stated it was for a 5 door 1.9ddis , when i got it a label was attached to it stating it was for a 3 door jeep, will this fit my 5 door, as i dont want to strip it all down and to find it does not fit.
3 door ones are bigger and will not fit the 5 door
Mite be ok as i contacted the seller about it and said they checked and to ignore the label as its for a 5 door, so going ahead with the strip down any advice on the door card removal.
Slotted fork type trim tool is best, remove screws in door handle cover (obvious) and in the door grab rail
You need to be a bit of a contortionist to get door and window controls plug out, after that its pretty straightforward
