What is a good winching battery besides the optima?Is there one?Those things are freakn high$$$$
With a Delco conversion you can run 150-200 amp single wire Delco alternators in your Zuke .This in conjunction with a 650 cold crank battery
(recommended by Warren) and you will be fine.......Boxcar...
Check out the DEKA batteries. The Optimas are now made in Mexico and just not as good as they used to be.
DEKA AGM Battery
There is a Deka distributor in Madison. A little more expensive than the Optimas and Exide Orbitals, but appears to be a better battery and made in the U.S. Not sure where the Orbitals are manufactured, but Exide does have a factory in Bristol.
The SuperStart batteries at Oreillys are supposed to be made by Deka and are much cheaper
Super Start 34EXTAGM - Battery | O'Reilly Auto Parts
