Hi All
I have 57plate Swift 1.3 and have just started to notice a high pitched whining noise when in second gear. It doesn't happen in any other gear. Can anyone give me an idea what it may be.
Please - the term "57 plate" means very little outside of the UK - in fact, all it says to me, is that you're probably in the UK.
A transmission whine is usually a bad bearing, start by checking the transmission fluid level, if it's low top it up and see what happens, you may catch it in time to prevent bearing failure - you could also replace the transmission fluid rather than just topping it up, which would give you the chance to run the old fluid through a sieve and see what if anything comes out.
