I need to put Freon in my 1999 Suzuki Grand Vitara. I cannot find where to put the Freon. Can someone tell me where the valve to the compressor is? I believe there is a leak but not sure. I had the compressor replaced in 5/2013 and the expansion valve and receiver drier replaced 8/2010. They put dye in the system put they can never find where the leak is. The AC system in my car is frustrating because I felt like I've replaced everything. Should I have them just replace all hoses?
The low side freon connection (service port) is behind the front grille, left side of vehicle viewed when seated.
You need to remove the grille with the several fasteners across the top, the pull the corners and bottom to release it from the push / pull type fasteners used.
But you have a leak, the source of same we don't know. :(
See the manual here...
http://www.mediafire.com/?cvrt1rfoso8t8
Grille removal instructions are in this link, but from another forum which will require you to join to view... ;)
Login
