1 - 12 of 12 Posts
I bought a 1982 SJ 410 and the cable from the temprature control on the heater levers goes thru the firewall and is not connected to anything in the engine bay. Does anyone have any idea where it goes?
Thanks for the image. It helps to know there is a water valve. I will check and see if there is a spot to attach a cable on mine.
I've searched the part number for the correct unit and found nothing available.
lowrangeoffroad do the samurai-413 valve at $70 and I have no idea if it will fit properly.
I also "Googled" -universal car heater water valve- and found a few. Something like this may well do the job if you can get the cable to fit..
Cable Operated Heater Control Valve
1 - 12 of 12 Posts
