I need one of these:
Mine's broken. I've looked all over the place and can't find one. Right now, my choke is wired open and I would like to have it working the way it's supposed to work.
And while we're here.... does pumping the gas actually do anything to help starting?
Try Trail Tough for the part. Usually pumping the gas puts a shot of fuel down the manifold from the accelerator pump.
If I give the peddle 3 pumps before I turn the key, it fires right on the first rev, even on a cold day. If I turn the ignition without pumping the peddle, it takes a few cranks from the starter before it fires up.
Checkin' with them. I need a skid plate and the starter clicker kit, too.
Baratacus- it takes mine about 4-5 tries when cold, but I suspect that's 'cause my choke is wired open. Once it's warm, fires right up.
