hi to all. Got my EVERY with the orig /stock 10 in rims. My friend said it is better to use 12s because they provide greater stability and safety. How about availability of tires for 10s and 12s rims? Any correction factor in speedo reading? Thanks in advance..
Your friend is right but thats only because the 12" rim would most likely be wider, hence more tyre contact. If your overall tyre/ rim combo stays the same size, you dont need to adjust your speedo, ie; you use a 15" rim with a 75 profile tyre. If you go to a 17" rim, lowering your tyre profile to mirror the old overall size will be fine.
