1 - 9 of 9 Posts
Does anybody knows whats the name of this piece? And where can get one? what I really need its the bearing? Is it easier to buy just the bearing or all the piece?
I appreciate any information, I need my car working good pleasee!!
By the way I have a suzuki vitara 2000
None of those Max - those are for the "other" belt.
That's the "fan idler" or "fan mount" - I'll get you the correct name in a little bit - it's used on the SV418 (1.8 Sidekick Sport), the SV420 (2.0 Vitara) and the SQ420 (2.0 Vitara/Grand Vitara) - it may be dealer only, and whilst the bearing may be replaceable, it's staked in there pretty good, so I have not been able to get it out to find out what it is.
Part #5 then
Fan pulley 2.0 LITER
$152.19
2000 Suzuki Vitara Parts - Suzuki Car Parts Catalog Online Store
The member may be able to pull some numbers off the old bearing or have a Bearing Distributor measure / match just the bearing needs, if he wants to attempt a fix.
I'd purchase the whole assembly Suzukini. OR maybe a good / used one if you can source one locally.
I replace the entire assembly - and then tried disassembling the old one - if I recall correctly there are/were no numbers visible on the bearing whilst in the housing, and I never got it out because of the way it was staked.
Thank you very much your information was very helpful, Im doing some research to find the best seller and price...
I had to replace the same thing on my 2.0 Tracker. It's not available in any of the big chain autoparts stores. I was in a hurry when I bought mine, and got it from a local Chevrolet dealer. Ended up paying over $170 for it. :( Next time I'll take the time to dig a little deeper.
1 - 9 of 9 Posts
