My 2009 GV has pretty low usage about 20-25K miles, it siddenly begin lightup the Transfer case/Lock Indicator ramdomly at the instrument cluster, I checked for bitten wires, corrosion etc, no cues on what what the cause, OBDII registered some ECU link failures.
Then It begin experimenting Engine Misfires, Given in my country Fuel supply is not strange to have contaminants I first checked fuel system, nothing, then Ignition/Spar-plugs I found my spark-plugs where in bad state, so likely the misfire source, I cleaned and recalibrate it, as interim solution and Misfires dissipated... But Also I begin to Miss that Weird random Transfer/Trnasmission Failure Alert.
Then I bought some "iridium" spark-plugs, and at the first run, while the engine run fine, the ECU , Gearboxe etc everything looked like a Xmas Tree, I was alarmed to have broken something while replacing the spark-plugs, The double checked everything was correct, nothing broken, Then I remembered an SCADA Project where an HV device leaked noise into the network, so I tried the re-installing the Old Sparkpluigs, and everithing went fine again...
I returned the "iridium"spark-plugs and got a set of ORIGINAL Platinum NGK Spark-plugs as listed in the manual, Installed and everithing Fine Since Then, My GV as powerful and reliable as ever.
(the "iridium" spark-plugs actually where Fake Chinesse copies of Denso).
