engine was running a little rough. noticed carb was loose tightened the two loose nuts now it whines loud and will not idle.i am cant figure it out.if i loosen the nuts it stops.but they need to be tight.whwt should i do?
It sounds like a vaccume leak. Get a new gasket and remount. You might be able to put a little RTV on the old gasket and try.
Also check the idle mixture screw at the base of the carb, if it's open too far, it can whine at you and show the same symptoms as a vacuum leak.
