Hey Guys,
When running a Weber carb with an elec fuel pump, do you recommend using the fuel pump block off plate and EGR block off plate?
webers
yes block everything and don't forget to have an extra filter with a return line connected to the original ski return line and also check the pedal stop bolt it tends to keep the secondary circuit from operate
The PCV Valve is still used, it's connected to the top of the valve cover and then there should be a white plastic elbow that has a piece that can screw off and attach to the bottom of your Weber air box. So the PCV valve is still a 3 connection hose system with a T.
