1 - 12 of 12 Posts
1995.5 Sidekick, 5 speed manual, 1.6L 16v
Any ideas why my water pump schreechs only at 1400rpm, and only on a warm engine?
Stethoscopes everything while my wife held down the accelerator, and it is the only thing making that noise. Weep holes aren't weeping coolent. All other rpm values are silent, as far as I can hear. Belts are tensioned the way the should be, and no pulleys are wobbling.
Remove belt and rotate WP by hand, bearing noise is not indicated by any leakage... rough rotation means a pump replacement...
Keep the keys in your pocket during this diagnosis and your wife out of the car!
The Timing belt idler pulley is VERY close to the water pump. Maybe?
That's a very good point - isn't the timing belt tensioner pulley actually mounted on the pump?
Yes, the tensioner sets right on top of the water pump. Good thinking. I'll take look at removing the belt later today and take a feel of the water pump bearings.
After popping off the belt, I put my sethascope on the water pump housing and turned the fan. I could hear the bearing moving and a lot of sloshing of the empleler, but I couldn't hear any grinding or anything that I would associate with a bad bearing. Kinda like spinning a wheel on a roller skate but smoother. There was just a tiny bit of play in the pulley.
I'll order a new timing belt and idler. Should I also just be safe and replace the water pump while I'm in there?
Also, my Sidekick has AC. How do you remove a radiator with refrigerant pipes going to it? Any way to do it without have to vccume pump out the coolant?
There was plenty of room in my 94 8 valve to replace the pump and rr the belt and components without removing the radiator.
Don
^_^
Yes, pumps are inexpensive and easy to get to while your there.
Don
^_^
Reactions: Bear95
If you’re doing the timing belt along with all of this, you have to remove the radiator. You need to discharge and disconnect the A/C system, etc., in order to get the radiator out.
Discussion Starter #10
This might sound silly, but how in the heck do you get the lower radiator hose off? I guess there is some clips that need a special tool to undo. I got one of them off, but trying to get the hose off of the tube that leads up to the outtake of the engine, I couldn't make it budge.
Do they cut these off and use a new hose every time?
The hose sticks to the hose bib, you may have to use a pick to break the bond.. I have used shop air to release the hose..
vaseline or silicone grease when you re fit it helps next time, light smear on the bib.
they can be a real sod to get off, you may end up cutting and replacing the hose.
1 - 12 of 12 Posts
