Hi, I have a water leak on my 2008 Jimny. I'll attach a photo to show you where its coming from. The drivers side footwell is also wet but this could still be wet from having a new heater matrix fitted 2 months ago. The leak drips for about 5 minutes after the engine is switched off (its clear water with no taste). Any ideas?
Welcome to the forum. Does this only happen when the AC is on, I see the evaporator connections are directly above where you have marked. It's normal for condensation to form and drip from wherever the drain is fitted.
Yep think the above is correct. I see there is a seal (19) to stop any water running back inside. If you think any water may be running down the side of it I would find a short piece of the correct size hose to extend it a little. Preferably curved down a few degrees.
