Hi can anyone help I have an 02 plate 1.3wagon r+ and it needs the camber adjusting as it has severe negative camber but I can't see any way to adjust it. It's not been in an accident and all the control arms etc are new but visually looking at the front of the car the wheels tip in at the top any help greatly appreciated cheers Jason
Hi M3dogg,
Can I ask you several info as: is your tyres worn uneven, in this case inside more worn compare to the outer edge of the tyre or the car pulling any side?
Also have you checked this alignment under load(around 100kg), since they are really light cars with relative long vertical movement on the suspension the geometry can change a lot under load.
In my opinion your camber aren't adjustable, as most common cars. If you want adjustable camber, I don't think you need, you have to go for some coilover set, but first go to any decent tyre shop, they have tracking (€20-30) and that tells you if any trouble with your camber alignment.
I hope it was helpfully, cheers
