There is only one W/W motor, the other wiper arm is operated via a reciprocating arm...
Maybe you could explain what the issue is..
... Philip
It's the "power window" motor he's asking about.
Use wooden wedges to "jam" the window in the up position - remove the inner door panel, remove the retaining screws, unplug the wiring and then remove the regulator assembly.
Replacement is the reverse.
