Hi there i hope some one can give me a answer . my vitara has been fitted with a hif44 carb with a BFM needle it will tick over very nicely but when its revved up quickly it has a flat spot about 1.5 to 2.5 RPM after that its ok the ignition side is still being run by the ECU [it was a single port injection system] a new low pressure pump has been fitted. i hope someone has a answer on this problem Thanks Neil
