All I have seen (US models) have a front/rear split..
The only cars I have seen with diagonally split brakes have all drum brakes.
Front discs to back drums, and most probably with rear wheel anti lock brakes.
Discussion Starter · #4 ·
Had a flexy off the front of mine and now having probs getting a good pedal.
Right (o/s) front brake pipe (from m/c) goes into some sort of brass manifold under steering column, copper pipe from that then goes to o/s flexy.
Cant see it easily, and cant work out work out which pipes are going where.
Just wondered if this set up was familiar to some of you guys.
You should advise your location. Presumably you are UK so your brake system will be slightly different than USA info here, which has the master cylinder on the left side of the firewall....????
A Vitara is split front to back with no anti-lock.
Bleed the entire system, you can do an initial bleed on the corner you were working on, but it needs to done starting with the RL, then the LSPV, followed by FL and finally, FR.
