Anyone know how to remove the bulb from the OEM foglamps? I got the assembly out but can't figure out how to replace the bulb. Also, anyone know where a new bulb can be purchased? None of the parts stores I have called show it available.
if your still needing help, uncrew the unit from the vehicle if you'd like. Untwist the back cap. The bulb is held in with a spring clamp. Just push it in and down or up and it will release the bulb. Make sure not the touch the bulb, you can purchase the bulbs at auto zone, just bring your old one in and they will match it up to an upgrade even if you want them too. (that's what i did). Then you just stick the bulb back in (connected), make sure that the bulb is matching up shape wise . . flat or round up or down, you'll see it. then just put it all back on and your ready to go.
