Hello,
I have verona 2004, I bought that car about month ago with ABS and check engine light on.
with the code P1382 as i searched online its the ABS but im not sure what to do if i can get help will be great, by the way the ABS not working now when i step on the break, I changed the Break disks after I bought the car because it was very bad almost metal to metal and the break work very good now except for the ABS.
The other code is P0133 which is refer to O2 sensor that I need to locate on the engine, I checked the Pic in other topic here in the forum but its not mach my engine (V6 2.5)
my car is verona lx
I hope i can get some help ans thank you all
I'm new here in the forum and I hope you all will accept me as member of this great family.
according p1382 gm would be a misfire or wheel speed sensor that bug but need to change the wheel hubs because it comes with just $ $ 250 for the room I have same problem with mine is a 2005, Your ABS What is the problem?
