87 Samurai with 1.3 stock, stock, stock. Vacuum advance tests bad (cannot put vacuum on advance. Diaphram evidently broke as I can suck air through hose.) Can't seem to find the part. Is it a universal advance or do I have to buy a complete distributor? Tips on changing if I can switch out just the advance. First Sammi. Got a month ago. Testing through all the systems. Bad mileage (15 MPG). Rebuild carb (Running rich) and tested ignition. Found bad vacuum advance. Appreciate any help. Thanks.
Thanks Hot Rod. I looked all over for just the advance and couldn't find any. My Sami does have the ngk wires. Older coil but it tests out to spec. Looking thru the website you pointed me to gave me some more ideas. Thanks again.:)
