1 - 16 of 16 Posts
· Registered
Hi, looking for some help regarding a Suzuki Vitara. USB port is broken which connects the phone to the Car Play system which support both apple and android
I'm wondering if anybody can offer any guidance on how to replace this, and what is a sensible price for a new one.
The USB port clip in because the tongue on the car usb seems to have broken so it can't grip it to connect.
The car is a 68 plate
Apologies for the rubbish description, hopefully the attached image helps.
· Registered
2005 1.6 GV 3 dr Auto
Hi Robbie and welcome aboard :)
This is an international forum - so you need to put year of manufacture on your post.
The UK number plate system means nothing to other nationalities.
· Registered
... and this gives you a fitting idea (amongst other useful info in the thread as a whole)
· Registered
I can confirm that popping it out is easy thanks to this very helpful post and pics. I took mine out a week or so ago to remove a stuck cable. Replacements are about GBP 70 on eBay.
· Registered
· Registered
the infortainment unit's also seemingly sensitive to leaving the phone cable plugged in Vs plugging it in each time you want to use it and unlpugging it when you've finished; plugging / unplugging seems to work consistently; leaving it in can give it a headache (at least in my experience)
· Registered
The iPhone cable was fine left in situ - well up to the point that it got stuck of course. Still haven’t found why. There were a couple of dirty marks rather than scratches so I used some contact cleaner and it seemed to free it up until the cleaner dried and it jammed again. When I get the car back from the missus I’ll use a different cable.
· Registered
39105-57L10 USB SOCKET
1 - 16 of 16 Posts
