Ihave a Suzuki Vitara 4 cyl and when it gets hot it cuts out . Let it cool a bit and it goes again.
I suspect one of the temp senders is faulty
Does the ECU get temp from a sender and can it turn everything off?
On my Kia Sportage I had a similar issue that was the crank sensor for the ingition. Could be a fuel system vapor lock. It could also be a coil pack that heats up. I would think an inexpensive OBD reader could help you better.
