a u-joint that i replaced less than 9 months ago has developed slop in it (moves a little when rotating the driveshaft). all other u-joints are perfectly fine, and been there since i purchased the car nearly 2 years ago, but this one is newish. what could cause slop like this? last time it broke it left some heavy wear marks on the driveshaft, could this unbalance the shaft and do damage to the u-joint? and does that leave me with the only option of buying a new shaft?
also, while trying to pull the shaft out, i got my brother to put the tranny/transfer case into neutral to spin the shaft to get to the bolts i couldnt reach, then had him put it back in gear... while doing so, the gearstick has jammed in position just to the right of 4H... what could cause this?
dont know if this is important or not, but the shaft is the one that connects the tranny to the transfer case, broken joint is on the transfer case end...
