FWIW, I tend to just use the Fel-Pro recommended dry installation. So far, I've never had a leak with Fel-pro gaskets.
I keep hearing that. I'll have to try it some time.FWIW, I tend to just use the Fel-Pro recommended dry installation. So far, I've never had a leak with Fel-pro gaskets.
Freeze plugs too.It does have its uses tho, works well on cork gaskets.
I cut a coolant gasket today from 3/64" coolant grade Felpro brand gasket material. For one of the inlet ports the rear of the engine, where the flanges on the "T" of the coolant crossover meet the heads. I had one gasket and nobody had a set in stock locally, so I made a 2nd one.FWIW, I tend to just use the Fel-Pro recommended dry installation. So far, I've never had a leak with Fel-pro gaskets.
Yes that's the one. The gaskets are at both ends of the T.
I'd never heard of this stuff. Would you use it with or without the gasket? (For future reference. I'll probably still use a gasket at this joint.)Smear if hylomar blue or plain bearing grease will do if surface is good
Yes that occurred to me too. I'll probably do that. I'd prefer no sealant here because it's a bear to reach that spot if I ever needed to clean it off.If I can recommend, cut another from the same material for the other side.
I cleaned and painted the pipe and fitted new o rings. Three of them. Two on the center pipe and one on the thermostat housing. All new gaskets. The old ones were ok but I didn't want to do it twice.How did you entertain the "T" center pipe 'O' ring joint fit-up?![]()
