I have a 2004 suzuki vitara 4WD V6
My dad and i added a can of freon to the vehicle and soon after the fuse for the blinkers blew. the flasher is fine, 4-ways work. might have caused a short while working on it?
i switched it (10A mini) and got a few days before it blew again. now when i switch the fuse and turn it on the engine makes a sound almost like the ignition is firing again for a few seconds and then the fuse pops and the noise stops. could there be something else going through that fuse thats seized and causing the fuse to blow?
i just dont want to spend time trying to find a short if someone here has had a similar experience and found it wasn't a wiring issue.
i hope i've provided enough information, any help would be appreciated.
