87 Samurai - all other lights works, except the right rear turn signal, the green arrow indicator light on the dash blinks very fast when the turn signal is turned on, any suggestions.
The rapid flash is a tell tale mechanism to alert the driver to the fact that a turn signal is non functional - in your case the right rear - check the bulb, check the wiring, especially the ground, and make sure the socket itself is clean and working - water can get in there and cause problems.
