Hi all!
Got two codes coming up after an engine orange/yellow light was on for as while and is now also blinking:
P0031
P0335 crankshaft piston Sensor
P0300 Random multiple misfire
Not passing DEQ.
2002 XL7 - 135 miles
Should i just go ahead and replace all sensors ? DIY?
Where is a good source for those...i don't want to buy crappy ones:cool:
Love our truck !
Thanks!
Hi all!
This is flashing because you have a miss fire.. P0300
P0031= B1S1 heater, https://www.obd-codes.com/p0031
P0335= crankshaft piston Sensor P0335 – Crankshaft position (CKP) sensor -circuit malfunction – OBD2 Trouble Codes
P0300= Random multiple misfire, This may be a result of the P0031, or P0335
Test faults before throwing $$$/parts at it.
.. Philip
.. Philip
Thanks phil!
I did not know all these codes are a standards between cars...i guess i'm putting some new batteries in my volt meter tomorrow and going for some diagnosis!
Will update! thanks allot
Also just went through the threads on the FAQ posting.
That a deep rabbit hole! wondering if battery replacement has anything to do...computer reset etc.
Removing the main battery will rest the ECU, but will not initiate these codes, unless you have a poor connection..
Perform a voltage drop on the main + and battery ground/engine..
.... Philip
