So I have a 1991 Geo Tracker manual 4x4. It is need of a transmission. So I went on craigslist and ended up finding a motor and transmission from a 1989 Tracker and after reading around I went and bought it thinking the transmission would fit. Now I have the Tracker up in the air and it doesnt look the same. Seems like just the bell housing looks different. I am lost.
Can anyone help me out with this.
Is it the same and if not can I just swap out bell housings to make it work.
Welcome to the forum. If you look here, at the parts catalog, you will see that tranny part numbers for some of the items (including the bell housing), changed, while some remains the same. The entire case assembly has the same part number from 89 and 91, so it would appear that you could just swap out the bellhousing. Don’t hold me to this - others may know better, but the diagram and part numbers seem to confirm this.
