I have a 2004 Suzuki Jimny and it appears to me that the auto transmission is suck in a high gear. When I turn on the switch, I hear a clicking sound coming from around the glovebox and also coming from the transmission. It moves very slowly when I step on the gas to take off and when it reaches a speed, it sound as if there is no gears changing, and the clicking sound also stops when the vehicle is moving.
Model Number: FJB43V Engine: M13A
I ran a diagnostic test and these were the results:
P0753. SHIFT SOL A ELECT (LOW V)
P0763. SHIFT SOL C ELECTRICAL
P0768. SHIFT SOL D ELECTRICAL
P0743. TCC SYS ELECT CRT (LOW V)
put the rear of the vehicle on jack stands and see if it shifts...... starting off in high gear will burn out your transmission.
Joe
It doesn't shift when on stands. When taking off on a level surface, you have to press on the gas and it takes a while to accelerate. The vehicle reverses fine but when in any of the forward gears it take a while to accelerate. I am certain that it is stuck in a high gear. It's like riding the clutch on a manual vehicle except no gears are changing. The transmission also makes a drone sound when it takes up speed.
I need to know if the ecu can cause this is or the transmission is ruined. As you can see from the diag test, there's definitely something wrong.
My knowledge on auto transmissions is very minimal..... I don't want to misguide you and hopefully someone else can chime in.
Joe
