1 - 1 of 1 Posts
I have a Jimny 1998 G13B 1.3L 16V RWD/AWD with transmission issues. I'm trying to get a rebuild kit. I want to confirm whether this kit from Cobra would work. The kit says 2000-2004. My Jimny is a 1998 with automatic transmission.
If not, does anyone know of the proper transmission model?
Any help would be greatly appreciated.
Brief history:
There was a delay, then hard bump, shifting from 1st to 2nd gear after rolling over a speed bump (when it did not come to a complete stop).
ATF was changed, however that problem was not solved.
I then ordered a transmission filter which I should be getting in the next week or 2. Sadly I did not get it in time before things got worse.
Presently, I am hearing this ticking sound from the computer unless it is in L.
Upon startup, at a stand still, I am able to move through all the gears.
It drives, but there is not much power. Not even enough to get up a 6 inch curb.
It also drives in reverse.
I am hoping the filter change and transmission cleanup fixes this issue.
Worst case scenario transmission rebuild, hence my question.
Hope I gave all the necessary info for your assistance.
Thanks in advance.
1 - 1 of 1 Posts
