Transfer case has a loud roar, figured bearing problems, I was correct, took case apart and found that the needle bearing on the output rear shaft was bad and looks like it has rough up and pitted the shaft, this needle bearing is located under the high gear. I may be able to smooth the shaft but don't want to take any chances. PROBLEM is: Can anyone tell me where to find a complete bearing kit for this case? everyone I find does not seem to have the needle bearing that I need. Also would like to find a output rear shaft. By the way this is a 89 Suzuki Samurai... Thanks for any assistance.
low range offroad carries the rear output shafts, and I think it includes the needle bearings. Check with them to make sure!
