I have a 92 tracker with auto trans and was wondering if anyone has swapped the weak little auto out for another type of auto that would hold up better? Thanks Kid...
Read the rest of the thread: 4sp OD MOD Replacement - Zukikrawlers... The AW372L (03-72L), however, is essentially the same transmission as the Suzuki's 03-72LE (found in 4d TracKicks and X90s). The only real difference is the 03-72LE is electronic and the AW372L is mechanical. Both bell housings and t-case adapters are fully interchangable. It is a virtually bolt-in setup, requiring very little in the way of mods past the tranny/t-case to make it work.
And as an added bonus, the AW372L factory t-case adapter uses the 'New Process' 6 bolt pattern that the Dana300/Atlas t-cases use and the tranny will also accept t-case adapters from the Jeep AW4 and the Toyota A44DL, opening up the TracKick to a whole host of new t-case options.
