'07 Forenza, My trans doesn't want to come out of park...the only way I can get it out is by pushing in the little keyhole release...I had an issue about a year ago, I wasn't able to get the key out of the ignition or shift from park...I replaced the park safety switch on the shifter...worked fine, until now. Could it be the same issue? If so, why am I able to remove the key this time....this is getting be be a pain in the @zz! any ideas? Thanks Chobie
Discussion Starter #2
I wonder if it has anything to do with the stop light switch...because mine wasn't working so I took it off to check it out and when i put back in it was working and the shifter came out of park without pushing the safety release.... but now I have some speed sensitive power steering light on! I have no idea what that is or what caused it to come on!!
