Hey guys ..
I ordered trailmasters 50mm lift kit for my 2015 Jimny, do you think I need the following parts as well:
- Extended brake lines
- Adjustable panhard arms
- rear shocks repositioners
- Castor correction bushes
Or will the lift kit be okay wothout them? Ill be using the car 90% on road (some areas have bad roads though)
Many thanks!
I would recommend the castor correction bushes.
The shock extensions won't be needed, the kit should have longer shocks.
The adjustable panhards are worthwhile but not necessary, be wary of aftermarket bushes as these can induce a terrible death wobble - I can testify to this!
Extended brake lines should not be necessary if you retain the anti-roll bar.
