Does anyone have any experience using the Trail Tough conversion on a RHD suzuki escudo/sidekick? Please share some insights and what you did or needed to get it to work on an RHD
First question - what trail tough conversion?
Second question - what RHD Suzuki escudo/sidekick?
You're more likely to get a meaningful answer if you make sure that people can understand your question.
sorry, just to be clear i'm talking about trail toughs Sidekick Tracker X90 Straight Axle Coil Spring Conversion Kit, fitted on a RHD 2 door 1994 escudo Japan version
I would suggest you contact TrailTough directly and ask them about fitting to a RHD vehicle - I suspect the "steering" arms that bolt to the knuckles are designed for LHD only, those, and the panhard rod brackets will be the areas that need to be reworked.
