1 - 11 of 11 Posts
When I got the 95 tracker body that I have the steering column had been trashed. The lock all busted up. Turn switch and wiring all destroyed. I want to just go pull-a-part and get the complete steering column and replace everything. I don't want to remove the existing column until I have a new one in hand. I need to now what all has to be removed to get the column out and what tools I might need that are not obvious. The closest pull-a-part is about an hour away from me and I don't want to get there and be missing some simple tool that will keep me from getting the part. Any help will be greatly appreciated. Thanks, Phil Cottingham
I will preface this by saying I've never had to remove my steering column. However, the FSM indicates no special tools, just a number of bolts. You may want a steering wheel puller as well, if you normally use one. See post #2 here for an alternative.
http://www.suzuki-forums.com/suzuki...r/113650-how-upgrade-your-steering-wheel.html
Basically, with the battery negative disconnected, you remove the steering wheel, disconnect the turn signal/dimmer switch, disconnect ignition wires at the connector, remove joint bolt at steering column joint, remove column lower bolts, remove column upper bolts, remove column. There is also a lockout cable that needs to be disconnected if its an auto tranny. Instructions here on Acks FAQS, but for a column with airbags - although the column part will be the same:
Ack's FAQ 96 Tracker FSM SIR Airbag
Bex, Thanks for the info. I really hadn't thought I would have to pull the steering wheel. I had planned to only take a part what I had to get the column out keeping everything intact. From what I can see it looked like the brake booster and master cylinder might have to be removed. My tracker is 5sp. and does not have an airbag. If I keep all the column covers intact I might can get out of pull-a-part without having to pay for all the individual parts. Thanks very much, Phil
You don't "have" to pull the wheel or the booster/master cyl. Push the seat back if the doner car still has one. Don't forget.you'll need a key for your new switch.
... Don't forget.you'll need a key for your new switch.
that (the key) is something rare at pick-n-pull. If you find one, you should consider picking up all the locks so they match. should be cheaper than re-keying.
There should be a key code on the right (passenger's) lockset. If you don't have a key, remove the lockset, go to a quality locksmith, and they should be able to reproduce the key. They may ask to see title/driver's license match. I've had this done twice for less then $20 for the initial key. It's been a few years ago so the price, surely, has gone up. McElheney's hardware in Toledo, Oh on Madison Ave for anyone near. Good luck.
Edit: posted as an alternative if no key available at JY
This is not a big deal. I'd swap the entire column. Start w/ column w/ a key. 'Few phillips screws on lower cover, 4 interior column bulkhead bolts, 2 column to dash bolts, knee bolster and column joint bolt in engine compartment. With column lowered, disconnect connectors.
Discussion Starter · #9 ·
Thanks Scotsman, That's what I am going to do. I need to replace everything about the steering column, covers, switches and all components . I hope to find a column with a key but that's asking a lot. Thanks, Phil
Discussion Starter · #10 ·
I just wanted to let you guys that helped me out know what I did about my steering column . In my search for parts I found a 94 tracker for sale that I bought for a parts vehicle. After looking it over I decided to use it as my project and the original one for parts. Now I want have to change the steering column and I have a key. Now this one will get the Isuzu diesel engine. I will have the engine and automatic trans. that I will probably sell for parts. Thanks for the help. I'll be chiming in later. Phil
Good luck with your project and let us know how you get on. Photos would be good....;)
1 - 11 of 11 Posts
