Changing xmsn on 96 3spd 4x4 tracker. Cut oring when putting torque conv on. what is the part number for this oring? Part of seal kit? P/N of kit where can I purchase? Believe this is the oring for the oil pump shaft or input shaft.
Bug
Are you talking about the seal that sits in the rear of the converter housing, that the torque converter slides into?
No. Its the oring the convertor slides over when installed in the transmission. The housing seals are all easy to find.
Discussion Starter · #4 ·
I have and yes lots of parts are available. But no one could tell me if this oring was part of there kit for sure. Didn't want to spend $35 to find out that the oring isn't part of the kit
I'm sure this is not going to be helpful at all....here is the EPC page for the torque converter:
Google Translate
and here is the case:
Google Translate
Is the oring you are talking about in either of those diagrams?
