Will the below Tires & Wheels work on a stock 88-1/2 Samurai Soft-Top without any problems?
(Click Tire or Wheel Name For Full Specs)
BFGoodrich Radial Mud-Terrain T/A
Part Number: BFG-55834
Tire Size: 215/75-15
Rim Diameter (in): 15 in.
Tire Construction: Radial
Tire Diameter (in): 27.90 in.
Section Width (in): 8.50 in.
Tread Depth: 17/32 in.
Max Load Single (lbs): 1,765 lbs.
Cragar V5 Wheels
Part Number: CRR-3655755
Rim Width (in): 7.00 in.
Backspacing (in): 3.750 in.
Offset (mm): -6.00mm
Wheel Material: Steel
Wheel Finish: Black
Wheel Construction: 2-piece
Center Bore Diameter (in): 4.250 in.
Load Rating (lbs): 1,600 lbs.
Mike
The tires will fit with absolutly no problems and it just so happens that i have 6 for sale right now... i just lifted my 91 samurai and need new tires, they are all about 90% tread. as for the wheels i dont know but the tires will fit on the stock rims
Cheers
Tzuki
Cheers
Tzuki
Thanks for reply but a little late, i lost my Sam a month+ ago after bad off-road accident but if i every get another 1 nice to know 215's fit.
