1 - 13 of 13 Posts
I've been searching for a throttle cable for my 93 Tracker. Checked all major suppliers with no luck. Anyone have any ideas ? 4x4 5spd 2 door convertable 1.6 8v
Do a search for the original part number 15910-63A01-000, and, replacement part number 15910-63A0V-000. Good luck.
EDIT: This is assuming it's a 1.6L, 8v engine.
Sorry, but why would a 93 Tracker be the SE413??? The 413 engine (1.3L) was only used in the very, very earliest 88/89 Sidekicks, and never on the Tracker. You’d have the SE416 engine (1.6L).
It’s suggested not to search for most parts using Tracker, but using Suzuki, as it is better supported. Throttle/accelerator cable here:
https://www.megazip.net/zapchasti-dlya/suzuki/cable-assy-accel-1591063A0V000
The part number, if you want to search elsewhere, is 15910-63A0V-000. You may also have some luck finding one in a junkyard,
I corrected the model# in my post. Thanks for catching my mistake. https://www.megazip.net/zapchasti-dlya-avtomobilej/suzuki/sidekick-8588/se416-18299/se416-my-92-95-327661/intake-hanifold-and-throttle-body-3809548
B95
Broken Throttle Cable
Any motorcycle shops in your area should be able to make you a new inner cable.
Take your old cable in with all of the broken ends so they can fab you a replacement.
1 - 13 of 13 Posts
